You can change the parameters of the
egress configuration for a 9920 device.
The egress configuration is view-only for SLX and MLX
devices.
In the Navigation menu, select
Device
Inventory.
In the Devices page, click anywhere in the
required device row except the Actions column ()
to proceed to the device Overview page.
Select .
The list of egresses is displayed.
Select Edit () from the Actions column
for the item that you want to change.
Complete the fields as described
in Create an Egress for Devices.
